cfg83 : I am assuming the car is a manual. Double-declutching is just a way of reducing the stress on the synchromesh when changing gear.
Normally, if you are coasting, then input shaft will be spinning the speed of the engine (700RPM), whereas the output shaft will be spinning at a different speed. When you go to put the car in gear (with the clutch down), the two shafts must be spinning at exactly the right speed, or the gear cogs will crunch badly. Synchromesh makes the input shaft spin at the correct speed as the output shaft, so that they can engage properly. If the synchro is worn, then the gears crunch (even with the clutch pressed down). When changing from 1st-2nd, 2nd-3rd, 3rd-4th, 4th-5th, you can quickly change gear (synchro will help you, gearstick will have some resistance to going in gear), or gently do it (gently resistance, when speeds match, gear will go in). If changing down from 4th - 3rd... Or, from neutral - 5th, the synchromesh has to do a lot of work. Double-declutching can reduce the amount of work it has to do. examples of double-declutching (1) Car is in neutral, coasting along at 40mph (2) If 5th gear would be 1500RPM, then rev engine to 1700RPM, *then* press clutch in, change gear, and it will change a lot more easily. (1) Car is in 5th, and you want to change to 4th (2) Press clutch down, put it in Neutral (3) Rev engine to a little bit above the RPM you would want to be in 4th (4) Press clutch down, and change gear. Double-declutching can also be useful for cars with worn synchromesh, particularly on 1st gear (like mine) :) SVOBoy : I do engine-on coasting, but, the motorways here tend to have lots of rolling hills, and the lorries are speed limited to 56MPH by law - gives lots of opportunity for getting good fuel economy! |
lol, what kind of car makes the EEEEEEoooo noise?
Also, isn't pulse and bleed exactly what we are tryign to avoid when we use cruise control? I thought that it's more efficient since we're not constantly speeding up and slowing down? |
hahaaha i thought you were talking about bleeding the brake lines. or maybe the clutch line.
I've tried 'pulse and bleed' with the piece of **** Suzuki I drive. Didn't work well in my case. Better kept at a constant speed.
"R-I-I-I-I-I-I-I-I-I-NNNNNNNN". Like a Harley getting *** raped by a Formula race car... Had no problem setting off alarms on parked cars. |
omgz, i hated that my beater diesel sounded like rice. but a glasspack was $20 while a new exhaust would've been at least $100, and running around with an unmuffled diesel is just crazy. sounded like a tug boat or something, i could idle through a parking garage and set off alarms.
https://www.fuelly.com/attachments/fo...dd07625374.jpg |
landspeed -
CarloSW2 |
And lets not forget the rice burners honnnNNNNNNNNnnddaaaa yaaaAAAAAAAAMMMMMMMMAAAAAAhhhhaaaaaaaaaaa and KaaaaaAAAAAAWAsssssaaaaakkkkkkkkkiiiiiiii
