Fuel Heaters
Do they work? Or just a 'Net myth?
Run down on the theory. Your fuel line to your injectors or carb are rerouted to a holding canister that is heated by your engine coolant. The now warmed fuel can be atomized into a finer spray by your fuel injectors resulting in a more efficient burn. https://brightgreen.us/explanation.htm Thanks |
I'm going with net myth. Properly design modern FI systems should atomize the fuel over a wide range of temperatures... But, it may be like acetone, where it can clean out older injectors, or in this case, help injectors that are in poor shape.
Red -
The Hydrogen-boost guy uses them in his solution : https://www.hydrogen-boost.com/ Other people have gotten mixed results. My mechanic doesn't want to mess with them because he doesn't want to cut the fuel line. They are common in (older?) Diesels for pre-heating the thick diesel fuel. In one Mercedes Benz, my mechanic told me that the fuel line runs *through* the coolant reservoir. I also agree that the older the car, chances are, the better the results. The one you are showing appears to be the best manufactured. CarloSW2 |
I may have some results to report on the Brightgreen unit. I have one on order that should be here by this week or next. I also have one of thier squirter units coming.
What kind of testing are you going to do? Can it be controlled? (Would be tough, I imagine, if you have to do a lot of wrenching to go from "A" to "B".)
Here's Tony's thoughts (Tony is a clever fellow): https://www.fuelsaving.info/atomisation.htm
diamondlarry -
CarloSW2 |
I don't think I'm familliar with the by-pass valves.
