13% mileage increase by relieving exhaust back-pressure?
I was looking up my car on www.cartalk.com and found this to be interesting:
Still, it's something of interest for those of us who never have to pass an emissions test. |
Whether or not we have to pass an emissions test, I think we should all carefully consider our roles as citizens of a world, with a fragile environment in need of our protection.
But yakno, whatever. Anyway, his results are most likely BS, I added a second cat to my car and saw no difference, actually, there was an improvement, but I realized it had nothing to do with the cat, or at least, nothing quantifiable. |
If the cat was clogged or burned out any vehicle would see a gain when the cat was removed.
Erm, dunno about the valve thing. I don't think dirt-trackers have this kind of problem. ;) The exhaust flow is moving plenty fast and plenty hot. Add one more reason to the "engines need back pressure to work right" myth...
Possible the cat was partially clogged, and I'm certain that the stock exhaust was at least a size or two less than the car would really like and with cruddy bends. A new exhaust with larger tubing from the engine back and a hi-flow cat would likely keep most of the mileage gain. |
I'm just confused about MPG and exaust restriction. I know that some racers remove the exaust system to improve power, but more power doesn't neccessarily mean more MPG. Or does it? I'd sure like to read more about it.
Engine RPM range
Each vehicle's exhaust requirements are so unique, that it would be hard to make a generalization. In this department (since I haven't found, or performed an experiment with this regard) I would be inclined to stick with the stock dimensions. RH77 |
rh77 -
I was thinking that maybe one good experiment would be to progressively restrict the tailpipe outlet by attaching smaller and smaller conical hi-temp steel tubes onto the exhaust pipe and seeing what happens to MPG. Even better for a flexible experiment would be an "exhaust choke" dial on the dashboard that would control a hi-temp butterfly valve in the exhaust pipe. I am only talking about tailpipe exhaust narrowing because that is the easiest mod I can think of. Here are some gizmos that claim to do something in the exhaust area, but I think they have been shot down : The Infamous Turbolator https://www.jcwhitney.com/autoparts/P...001736/c-10101 https://www.performancepeddler.com/se...tor&x=0&y=0#a3 ... and it's bastard son, the MINI EXHAUSTONATOR https://www.jcwhitney.com/autoparts/P...haust+tip+MOpG ... hmmmm, maybe a powered Turbo-Mini-Exhaustinator? YL(aughter)MV CarloSW2 |
What theclencher said. There are situations, such as high output modded engines that can benefit from open exhausts, but even then, high flow cats and mufflers are made, and are usually suitable. In the past a manufacturer would tune an exhaust such that it would resonate at some rpm, generally at around peak power, because it would help volumetric efficiency and boost peak power output a wee bit. What happens is that at certain engine speeds, depending on the design of the exhaust, the pulse from a previous exhaust valve opening will bounce back from the muffler and reinforce the pulse from the next valve opening, which would provide better scavenging (pulling the exhaust gas out of the cylinder), and the equivalent of a couple psi of boost compared to the usual scavenging. If we ever hear muscle car enthusiasts talking about matching the intake and exhaust, this is what they mean. An exhaust can have this scavenging effect at some rpm depending on how it's designed, and longer runners on the intake help out with low end power, while shorter help with high end power. If we have a long runner intake with an exhaust that'll scavenge best at a high rpm, the engine will be kinda flat. There are also butterflies on the exhaust, and intake runners with different lengths that open up depending on rpm. Newer cars have variable valve timing, and can fiddle with the timing so that scavenging occurs at a much wider range of engine speeds. This, combined with drive by wire, aka lots of throttle tip in, helps out low rpm efficiency w/o any change needed on the driver's end. :thumbup:
Hello -
Based on theclencher's post, I was googling "car throttled exhaust system" and found this : TIGERS: Exhaust Gas to Electricity for Reductions in Fuel Consumption https://www.greencarcongress.com/2005..._exhaust_.html I am sure we have talked about this before, but it seems germane to the thread in a tangential sort of way. CarloSW2 |
