List of aero mods
[This thread will be a work in progress.]
Good list metro. I don't think you mentioned side skirts.
https://www.autotech.com/images/produ...olf_sskirt.jpg |
I though side skirts were more of a downforce producing mod than a drag-reducing mod. (Combined with a low front air dam they reduce the pressure under the car.)
I've only ever seen them mentioned in handlin/racing applications. Could be wrong - anyone have any references? |
Yeah that picture above definitely has some downforce characteristics in it. I always thought they would benefit aerodynamics because they prevent air from coming in through the side of the car.
Example 2 https://www.bodykits.org/_pics/_selec..._promo_pic.jpg |
The one in that pic is probably more for show than anything else. ;)
One thing to note the photo - the side skirts would be better if they incorporated a rear tire air deflector. It looks like it tucks in right before the rear tire, directing the airflow right at the tire :thumbdown: For an aero-minded side skirt, it should not extend any lower than the lowest point of the vehicle. That way you are not increasing your projected area in a cross-wind, but you will keep the crosswind from directly hitting any exposed parts - kinda like an air dam for the side. |
Composite Headlamp Conversion
4 Attachment(s)
How about headlamps that fit flush with the car's body:
Attachment 212 Vs. Attachment 213 Do you think there's any real aerodynamic improvement? To tell you the truth, I like the square headlamp style better (in terms of looks). |
I'd say it's likely one of those "tiny but real" improvements. Partly because it's not a uniform bucket (unlike, say, a hole in the matrix of a vertical grille which you could block from either side for the same effect).
I'll add it to the list. |
edit: use masking tape to protect the paint. |
