https://en.wikipedia.org/wiki/HCCI Ernie |
usedgeo -
(copied from https://www.gassavers.org/showpost.ph...18&postcount=2) Thanks for making a new thread on this. I keep imagining a "clicking dial" on my dashboard that goes from "off" to different resistor settings that mess with the IAT input. Different cars can have different resistors. I don't think a potentiometer would work because the resistance range is too great (right?). 1 - For car ECU/PCMs that like this mod, I think it makes a big difference. I also think that, if possible, it would be nice to know what the emissions are. For the purpose of an experiment, anything goes, but I also want to know the long term effects are on the emissions. 2 - You'll burn your valves out! Ha ha ! This is the "A Christmas Story" argument, aka "you'll shoot your eyes out!". How is you engine doing? Can you gauge the engine temperature with and without the mod? Since we are "driving gentle" I don't think the engine is at risk, but I would like to know that the long term effects are on the car and what the "danger zone" is. CarloSW2 |
MetroMPG -
This will become available on the next generation of SG software, where you have programmable gauges. CarloSW2 |
usedgeo-
1 - Get a high temperature thermometer that is rated to about 1000 degrees. 2 - Install it post catalytic converter. EDIT : INSTALL IN EXHAUST HEADER, NOT POST CAT 3 - Run the car as normal without the IAT mod. 4 - Run the car with the mod. In step 4 you *should* see the temperature increase as compared to step 3. If the temperature increases 180 degrees F over the temperatures in step 3, then you are in danger of damaging your catalytic converter (EDIT : DAMAGE WILL RESULT TO VALVES, NOT CAT). For me, that would mean shooting for a "safe" maximum of 100 degrees F over step 3. EDIT : SEE (https://www.gassavers.org/showpost.ph...19&postcount=8) FOR SOURCE OF INFO. CarloSW2 |
What may happen is the table for the fuel injection has entries for that false air temperature but the O2 sensor can only correct for slight deviations from the table entries. If you have a lot of EGR gasses coming back in then that would reduce the NO2 levels. Isn't NO2 Nitrious Oxide and a combustion enhanser?? Humm that would explain the dizzyness I felt one time when I got a big whiff of a car's exhost.
If that's the case, will an altered O2 sensor correct the emissions increase? EFIE makes a voltage alteration chip for the O2 sensor that exists so that you can make the O2 sensor give off a false reading.
yes but again it can only correct so far - within the expected variations that is programmed into the ECU injection tables. This is why when a Turbo is added the tables have to be reprogrammed to allow for more than usual fuel when more than expected air is forced into the engine and to run a little richer to prevent detonation. Changing the readings from the O2 sensor will operate the CAT at the wrong temp fuel gasses mixtures and could result in costly damage but it sure does increase the MPG!
repete86 -
CarloSW2 |
I would have been doing this with the intention of reducing emissions. I'm going to have to do more research to find a way to fix this problem. My mileage improvements have been done for environmental, not economic reasons.
repete86 -
Lean-burn, from what I understand, reduces HC and CO emissions. It's the NOx emissions that go up. NOx emissions is the bain of diesels. I think that the key to Honda's new clean diesel is the emissions scrubber : Honda Previews Next-Generation Engine and Power Technologies https://www.greencarcongress.com/2006...previews_.html Quote:
CarloSW2 |
