Okay, maybe I'll just start up and go. I bet that would save quite a bit of fuel. I think I spend probably about 6 minutes a day idleing, and 8-10 actually driving.
I also park in the garage so the car never gets that cold anyways. I'll just start and go for a while and see if that helps. Thanks for the tips! |
Why not use a 5W or 0W synthetic oil? Anyone?
The advice above is good, in particular:
For the morning journey - get an engine block heater, use it before each journey. This will dramatically reduce the outgoing fuel consumption (and, the engine will get closer to full operating temp on the outgoing journey, so will be a bit warmer when you go to do the return journey. - Grille / rad block to help the car warm up faster - Start the car, leave it for 10 seconds (unless you can roll off your drive in Neutral). The 10 seconds is just to let the oil get around the engine (should take just a few). - Drive gently, but get up to speed efficiently, not labouring the engine. - It is more efficient to use 40-60% throttle, even when cold, to get up to the right speed, then choose 5th gear. Return journey. When arriving at your destination, put an engine blanket on - without creating a fire risk. This will hold in a bit more of the heat. If you could plug the EBH in at work that would be brilliant, but not likely to be possible When arriving at home, try to arrange it so that you can quickly get the car where you want it e.g. lined up in the garage, then switch the engine off. On my car (small 1.8 engine), the fuel consumption at idle is like driving at 10-20mph, so you lose fuel economy simply by idling. |
