kitcar |
05-28-2007 02:03 PM |
Originally Posted by MnFocus
(Post 52942)
Better start saving now 17 years is 'barely' enough time !
The kitcar method is right here about 10 threads down , either '1st big test' thread or 'my videos' . He did a pretty good demo using a propane torch and a workmate .
A g2g might be a pretty neat deal .
Darn easy to do. Just be careful with the heat. You don't need the apex of the flame tip but the outer light part of the flame. It's a gradual heating process. Too much heat will make it brittle. You can do a grill blocker without a workbench. Attach one side (top or bottom) to where it's going to be and gradually heat the stuff applying pressure to form it to the shape. Finish attaching and you're good to go!
Another thought (GM actually came up with this) is that you don't really need to totally block the grill off. A lot of Dodge Dakota guys use (honest to God) metal gutter guard as a grill guard. Rocks can't get through those little holes. This also blocks air. That's why GM SUVs and trucks have those metal inserts in them now. They did a test in 2000 on a Silverado with cardboard taped on it including blocking between the body and frame.
