I didn't really think it would work but it was worth a shot mentioning it :) That pesky O2 sensor just keeps taking all the fun out of goofy ideas.
On your car does the converter stay locked up when coasting in gear so it coasts with the injectors off like a manual trans car would do while coasting. If it does I wonder if coasting in D with the injectors off but not coasting as far before having to resume driving would be better than coasting a longer distance in N but using a small amount of gas idling the engine? |
I'm suspicious that the scangauge recalibration might have been the biggest factor in the change you saw. Was the change in the right direction to explain your improvement?
That said, the grille block should help you coast a little faster, so there is some real improvement in there, most likely. |
Find out! Take it out on a flat road, warm up and plot a speed<->mpg curve like I did when we were talking about it way back. I found a sizeable difference because of the aero just between 45 and 50. If you find that grill block flattens your curve out past 45 a ways I'd love to know. |
Coyote X -
CarloSW2 |
Bill in Houston -
CarloSW2 |
Carlos, taking the O2 senor off-line could do the trick. I think that is one of the ways to overcome the mileage reduction I saw when I was experimenting with my MAP sensor mod.
Edit: Also, the correction factor could possibly account for the gain. I would sugest trying Carlos' idea and do back-to-back runs with the different SG values to verify it. |
At highway speeds I've been seeing negative value to trying to pulse and coast, though. The drag brings it down too fast. Let us know if you get some good comparative data and what your secret is to pulsing a minivan. Quote:
savoF3 -
In terms of rounding, you can change the units to Liters in order to see LPH instead of GPH. The LPH will give you better precision : 0.5 GPH = 1.89 LPH => 1.9 LPH on ScanGauge 0.6 GPH = 2.27 LPH => 2.3 LPH on ScanGauge Conversely : 2.0 LPH => 0.53 GPH 2.1 LPH => 0.55 GPH 2.2 LPH => 0.58 GPH I should make myself a handy conversion chart. CarloSW2 |
Well I've coasted down the hill several times before with the SG2 and got about 75mpg. I guess at a -19.4% correction this would equate to about 105mpg. 75 is about 71% of 105. With almost a 20% correction this would be about 91% give or take. So it was probably the correction factor.
Question about the P&G, or pulse and coast I guess. If I did the method of speeding up to 60 and using the coast function of the cruise control to drop to 55 then cruise back to 60, would this be the same as turning off the cruise then getting the speed back to 60 manually?
