Leaving the windows cracked just a wee bit makes a big difference in how hot my car gets inside.
RH77, if you hit the recirc button, you can keep the outsude air from coming in. But I think I am misunderstanding something. For me, I turn on the fan, recirc the air, and then manually cycle the compressor to get the temperature I want. |
Dittos on leaving the windows open a bit.
Having a garage is always nice, too. m |
RH77 |
Windows down going downhill
I have been warming up the car for maybe 30 seconds instead of a few minutes. I now crawl (just let it idle in while in gear) up the block and my car is just about warmed up by the time I hit the corner, so Im no really driving off wit the car still cold. I also roll down the window about halway everytimne I half to brake on a hot day or when Im coasting downhill. have an aoutomatic 98 Camry and coast with the engine on by just poppinh the gear stick into neutral. Not bold enough yet to drive with engine off. Personally, I dont think its bery safe. I always wonder if the constant shift from neutral back to gear will mess up my tranny or if the constant rolling down then back up of the windows is bad for tranny as Im putting extra load on alternator with window motor. Lastly, I always try to EOC into my parking spot if I dont need to turn and can just roll into an easy spot. (Difficult on my block as parking is a nuisance) but easy when I visit my girl as she has hydrant in front of her house https://www.gassavers.org/gaslog/sig.php?id=547 |
