Whatever you do, you want to stay away from open loop or some kind of WOT enrichment. |
Thank you gentlemen for the input above.
I once thought that shifting to "3" when gliding may induce DFCO but now it seems that the consensus is gliding in "N" should save most fuel. With your input, I will have lots of materials to try to understand and lots of experiments to carry out:). In other words, there will be enough to keep me busy in the coming weeks/tanks. There are legal and other limits as to how much I can do though. |
p&g works awsome in my auto i wouldent break 30 before i startd and now my best p&g tank was in the 38 range
Actually as of yet I have not seen an increase at ALL in MPG while P&G however I still have a 1/4 of a tank left. Although that could be to a few other issues and will continue to test as well as EOC ( Engine off Coasting ). |
Thank you Zvolen.
Safe and happy motoring! |
Sorry, I wasn't clear. Is the air flow through the throttle definitely linear with respect to throttle position sensor reading?
Heh, yeah, well, probably not. You may be able to infer that from the fuel maps or some crazy fluid dynamics. The easiest thing would be to go on a dyno, and see if you can have the TPS signal and torque logged simultaneously.
Where I was going with the idea was that I might be at 80% of available torque when the throttle is only (to my foot) only at 60%. And that pressing the gas to the point that feels like 80% might over shoot the max efficiency point. It would be nice to prove it with a dyno, for sure. Okay, I think I'm done thinking out loud now...
Hockey4mnhs,
Thats a conservative 26% increase!! Really!? Do you have a four speed auto, or an auto with overdrive?! Quote:
