popimp |
07-31-2007 05:09 PM |
I like that Mobil 1 is finally pushing for extended oil drains using the extended performance oil line. The only thing that I don't like is that if your car is still under warranty than you have to follow the oil life sensor or owners manual. But if it's not under warranty, your covered for 15,000 miles or 1 year. Does this even make sense? Also it says if your operating under sever conditions to change your oil as stated in the owners manual. I think it's so they can weasil out of paying up, by saying your car was used under severe conditions so your SOL. Here's the warranty info for Mobil 1 Extended Performance.
This is a limited warranty covering the Mobil 1 Extended Performance lubricant you purchased. ExxonMobil warrants its lubricants to be free from defects and will replace any Mobil lubricant that is defective. For vehicles covered by a warranty, follow the vehicle's oil life sensor or the oil change interval recommended in your owner's manual. Follow your owner's manual if the vehicle is operated in any of the following severe services: racing or commercial applications including taxis, limousines, etc.; frequent towing or hauling; extremely dusty or dirty conditions; or under excessive idling conditions. If your vehicle has exceeded the duration of the manufacturer’s warranty, ExxonMobil warrants that the Mobil 1 Extended Performance lubricant you purchased will protect your vehicle’s critical engine parts from oil related failure for 15,000 miles or 1 year, which ever comes first. If not, provided the engine was serviceable at the time the oil was installed, Exxon Mobil will have your vehicle repaired and replace the oil at no cost to you.
