popimp
On the bottle ACEA A1/B1 ILSAC GF-4 API SM,SL/CF All I know is Ive been using M1 for years. My Ranger doesn't like it. Its the only car / light truck Ive had that disliked M1. For some reason it likes to burn it and rattle. So until some lab rats can tell me its for sure not the oil it use to be. I guess I will keep using it. I think its the best off the self oil available in my area. And I will keep running on the long OCI's psy |
after i took out my k&n my #s went up really easy. it was actually killing my mileage. it went up from NEVER being able to beat 30 to way over 30
Wow, I'm glad I read this thread. Any paper filter brands you would receommend?
On second thought, is it possible you guys aren't cleaning your K&N's properly? I usually clean mine with every oil change. I'm pretty sure mine is doing its job, because during the winter time when there was a lot of salt dust everywhere, the thing would plug up and I'd have to clean it often.
Also, I'd have to double check, but last time I looked my wife's Saturn (paper filter) had more dust "on the wrong side of the filter" than mine does -- a very thing coating of fine particles down the length of the intake snorkel. I don't remember seeing that on mine. |
I think FRAM is pretty good and readily available. I use Amsoil EA Air filter. Their supposed to be good for 100,000 miles or 4 years. Easy cleaning using shop air or a vacuuming no oils no mess.
Hum
I bone dry the car until I can put in atleast 13.5 gallons. Thats how I am calculating Miles per tank. I know I could just divide, but.......im lazy like that.
I can only comment on my experience with the K&N-I did research online and decided to try it. I am running the prestone platinum synthetic oil at 5w30. Supposedly oil change every 75k. We will see..... |
psyshack -
CarloSW2 |
I've been splitting the difference between medium/low cost dino oil and high end synthetic. Been using WalMart synthetic, in the recommended weight for my car (10-30) it's about $3/qt.
I figure it's likely not as good as Mobil One or other top shelf synthetics - but definitely should be better than cheapo $1.50-$2.00/qt dino oil. FWIW. I used to change it out at 3K miles but I hope/plan to go 4K as long as it doesn't look nasty. And change out a couple qt. of auto trans fluid at the same time, this gives me a rolling change of tranny fluid so I don't have to pay major $$ to change it all out at once. That way I think I can afford synthetic tranny fluid. |
