No freakin way!
You won't believe it! I bet someone calls me a liar! Check out my most recent gaslog entry!!!!! Its late, so Im going to sleep!!!!!!!!!!
Nic |
Nice, I bet you'll be doing it without thinking about it before you know it.
(course it was a short tank) |
I filled up at half tank, so it wasnt really that short. Nearly 300 miles...
I figure I EOC'd about 90 miles out of 298. Diligence! |
Nice job, congrats!
baddog671 -
298 miles / 3.82 gallons = 78.01 MPG Now, remove the 90 miles of EOC : 208 / 3.82 = 54.45 MPG Since your previous tanks were in the 50's, the 90 miles EOC definitely shows in the numbers. Were you already EOC'ing in your previous tanks? Congratulations! CarloSW2 |
WOW nice gotta love the eoc! it really makes you want to hypermile when ya get tanks like that dosent it?
Nice! I hope that trend stays for more tanks. That is a small amount of gas, so your error is likely high, but no matter what the error is you have certainly improved a ton.
Nice going!
FWIW, I typically filll up about 4 gal, sometimes about 6. Results are pretty consistent as long as I fill up at the same station. Since I have no Scangauge or SuperMID I like to top off frequently so I can get the "feedback" re. how I'm doing. So I wouldn't worry that the "short" tank threw off the results. I think the nice mpg is due mostly to your diligence and hard work. |
Nice job. Congratulations.
Any errors would show up in the long term calculations anyway. I don't think short fills are bad, especially if someone doesn't drive often and doesn't have a scangauge since there's no other way of checking their FE.
