my gauge does the slow first half tank then really fast on the last part also it might be a honda thing also??
Thanks TomO, that link was quite informative. I found that in my '85 Accord that half tank was pretty close to being an actual half tank. I think I like DaX's approach the gas tank:
Gas gauges are gas guesstimators!
Both my Tahoe and my Saturn get most(about 2/3+) of their miles out of the "first half" of the gas tank. Once they hit half the gauge drops like lead bird poo. Same deal with my Explorer I sold this spring. My Tahoe has a 30 gallon tank and only takes 25 gallons when on "empty". :rolleyes: |
Yeah, my gauge is rapidly headed toward half tank as I come up on 250 miles.
ive gone almost 80 miles on the first "quarter tank" but i usually get about 250 a tank, i doubt my gas mileage has improved that much :p
The gauge is not unreliable, it's just inaccurate. It will act the same way on every tank. It's purpose isn't to let you know how many miles you've gone, it's to tell you when the tank needs filling again with a rough estimate of how much you have in there. For this use it's very accurate, because it tells you that you have a little or a lot of gas, and tells you when you need to fill the tank. Run a few tanks through and you'll get a feel for it.
Well, I've hit a 1/2 tank and am at 295 miles. Going to Worcester today (I'm on the Mass/New York border and Worcester is 30 miles west of Boston. It's about 100 miles each way. So I should be able to get out there and back home again before needing to fill up. That would take me to about 500 miles. We shall see.
In Worcester with 435 miles now. Gas gauge is still above 1/4. 600 miles may just be within reach. Although I may fill up here in Worcester as gas is twenty two cents cheaper. Drove 80 miles on the Mass Pike at 65mph most of the time, dropping to 60 during neutral gear "glides" down hills (engine on) and 70+mph my upper end. The speedo and odometer worked the entire time on the highway. It seems once the car has beening going for awhile it isn't so buggy. But when the engine is cool? or dinking around town it not working for much of the time. I dragged for a total of about ten minutes behind a truck toward the end of the trip. 550 miles at least seems very possible. Rear tires were underinflated this whole time. Put them up to 46 PSI Right before I left to Worcester. They were at 39. They're rated at 44. The fronts are rated at 35 but had also been at 39. So I left them there.
