Re: Bigger fuel tank for a civic vx ?
I frequently had 500-600 mile tanks in my 95 VX. I had the 10-gallon tank. I had one tank of 680+ miles (77 mpg on the fillup). Spectra Premium makes a 13.5-gallon tank that will fit a VX.
The most I could fit in our 92 VX(canadian made/canadian model VIN), was about 10.5 gallons; while the car's passenger side was lower than the spout at the gas cap. So, level ground 10 gallons seems to be reasonably what this tank is. I have a hard time believe it is 'truly' a 12 gallon tank since it cuts off 2 gallons short. A true 12 wouldn't need 2 gallons of 'top off' near bone-dry. We're not talking about the normal 'top off in stages and potentially flood your EVAP system either).
Sorry Arky. VX have 10 gal tanks so if you're sure you put in 12.xx gal u have custom tank installed by Chris. |
Check my gas log. I've put well over 12 gallons in my tank. If Chris put a custom tank on it, that's great. The more gas I can carry, the further I can go!! :) :) :) A couple of extra gallons isn't going to hurt FE.
When you going to post some pictures of that jelopy, Seabass? ;)
Eventually i will. :)
^Well, ya got me beat on paint job and antenna! lol, my VX still needs a bit of work. Ugh!
The tank in Arky's is the factory tank. I can't see any reason you couldn't put the larger tank in any year vx. The chassis are identical for the 92-95 hatchbacks as far as I know.
The US 92 VX has a 11.9 gallon tank. The fuel gauges suck. I have had 4 civics with that tank. They all read empty with about 3 gallons left. The 93-95 VX has a 10-gallon tank. I could overfill mine to 10.2 if it was bone dry.
