maybe simpler solution...
FOR SALE: Honda engine with 100K miles. Runs great. Needs new Distributor and hoses which were removed when I swapped in my new engine. $150 Date: 2007-09-18, 3:20PM CDT Location: Duluth, MN |
i only have 110k on my car.. an engine is a little extreme haha im gonna check the ignitor today, i found the section in the service man. about checking and replacing
Different car, but my wife's '99 Acura was doing the same thing.
It wound up being the ignition switch, it had an electrical short in it. Found out by jiggling it slightly and the dash would go dead and then come back. Hope this helps. |
Dunno... I was looking at the '92 VX page.
They list the same distributor model for all VXs - TD-42U... But for some reason they have a different ignitor part number and price for '92-93 and '94-95. |
I heard that some of the older Accords did this (jumpy tach) and in their case it usually turned out to be a bad ignition coil.
Jumpy tach and loss of power is almost always the ignitor. I've also been able to swap pretty much any 88+ honda ignitor with any other 88+ honda ignitor, might require some grinding of the ignitor to get it to fit in the distributor housing, but it works. =)
For those who really want to know how a Honda ignition works, check out this article.
https://www.tegger.com/hondafaq/ignit...ion/index.html |
well.. i started the car this morning and had a bad squeal/squeek coming from the distributor area.. lucky thing i heard this on my way to the parts store and not after.. because turns out my distributor has apparenly been crapping out on me slowly but surely, had i of known the tach insanity was a sign.. i couldve avoided all of this.. but i bought a new distributor today, and when i took the old one off and compared it to the new one.. the old one grinds horribly when you spin it, and on top of that it would catch every couple of spins and you'd have to force it to get it to keep spinning... im guessing that could've had SOMETHING to do with my issues haha.. well once i got the new dizzy in and adjusted the timing(as close as i could..) i took it for a spin, now the "lean" doesn't kick so hard and its actually smoother accelerating.. im hoping this may help my low MPG issues slightly... thanks for everyones help!
Sounds like the bearings were on their way out. I've had one distributor personally do that on my hondas.
