Gary Palmer |
10-01-2007 09:23 AM |
It sounds to me like the Syncro on your 5th gear is a little worn. All you should need to do is put it in neutral, let out the clutch, engage the clutch, easy 1-2-3 slip it into 5th and release the clutch.
If you have the engine turning over at approximately the same speed as the transmission gears being turned by the wheels, the syncrho doesn't have to do much to get the gears turning at the same speed in the transmission, so that you don't get a grind when your trying to shift. Grinds are definitely bad.
When your in neutral, engine off and you press down on the clutch, to put the car into 5th gear, it is going to work the syncro, very hard, because the gears are fundamentally being spun from 0 rpm to whatever speed they would be turning at, if the engine were running. You can probably get it to work by engaging 5th at a slower speed, in pushing the gear lever in, so the syncro has a few more seconds to get the gears up to speed. Just give it a light touch, a couple of pounds, until the lever moves easily into gear. When you push it harder, it has to work a lot harder, because it is trying to get the gear to spin at a speed which will allow the gears to not interfere and grind.
