For my 2007 Toyota Yaris, 1.5L, I use Mobil1 Filter, and Mobil1 0W-20 synthetic except during the summer, when I use Mobile1 0W-30. The car is spec'd for 5W-20 but I want less viscosity during start ups to minimize cold wear & tear on the engine. I change the oil every 5,000 miles. I believe that flow is more important to engine protection then pressure.
Except when you use Synlube then even 5-6 psi is enough to keep the bushings lubricated . . . Miro didn't recommend that I install a mechanical oil pressure gauge because pressure would not matter when using Synlube since the lubrication is provided by the solids in the lube and not the hydralic pressure. Seems weird but it is working great so far.
I'm not saying that solid lubricants are not necessary - I'm just saying that given a journal bearing with a properly functioning oiling system, there should never be metal to metal contact (where you'd want/need solid lubricant). |
Actually it probably relies on the oil film strength since the piston is seeing 190 psi and the piston area is far greater than the curved bearing surface so you are seeing much higher pressures on the bearing even before the spark ignites the fuel than the oil pressure is providing.
I switched over to Amsoil in my 2001 Chevy Impala right after it turned over 201,000 miles for the extended oil and filter changes. The Amsoil 10W-30 Synthetic motor oil and filter are rated for 25,000-mile change intervals. I have almost 205,000 miles on the car now and the oil still looks like it was when I put it in. As an added benefit my Impala gained 2 mpg, it starts easier and is smoother running with Amsoil. Now I expect to get another 200,000 miles out of the car as long as the rest of the car doesn’t wear out before the engine.
In addition my buddy and I did a little lab test Redneck style. We took a capful of Amsoil ATF and a cap full of petroleum ATF and put them in separate drip pans. Then we took a torch and lit them on fire. The Amsoil immediately tried to move away from the flame before catching fire. We let it burn until it went out waited for it to cool and the Amsoil ATF was still liquid and slippery. The petroleum ATF lit off immediately, produced really black smoke and turned to charcoal like burning something in a frying pan. There was a little liquid left in a corner that was like stepping on gum when I ran my finger through it. https://www.lubedealer.com/T&SMay/fea...ductsview.aspx |
Your right it will come in handy when the tranny catches fire!
It also helps extent the life of transmissions used in towing applications that tend to run hot. |
