Gary |
Hey 1993CivicVX, can I proclaim myself as the king of stock CA VX mileage?
I got gas today and calculated 54.8 mpg!!! Thats with alot of drafting and about 95+% highway driving. Drafting really works. My best last time was 52mpg and I was drafting and going through the santa cruz mountains daily to/from work. Perhaps I could have gotten 55mpg if I didn't overflow my gas tank after two clicks. I just ordered a federal VX ECU/ECM and I'm going to order the wide band O2 sensor to convert my VX into a fed one - I want lean burn! If I didn't draft, the best I could do is around 48mpg. Gary BTW, I entered my last two fillups into the gas log. |
nice one. :) Congratulations. I think you'll notice quite an improvement with the FED conversion. Once you get converted we can do a little competition. :P
Although if most of your driving is highway I don't think you will be able to get into the 60s (unless you do some hardcore tractor trailer drafting) The reason I can get great mileage with little effort is because of where I live. Most people are happy to drive below the speed limit. And all the speed limits around here are 30, 35, 40 and 45mph. The few places that are 50 and 55 I try to avoid. So imagine driving average speed of 40-45mph on the highway with pulse and glide. That is in effect what the majority of my driving ends up being. Except that I'm stopping a lot at intersections and what not and often doing short trips. I think if you drive with your VX once it's converted the way you drove on this tank you will get 59mpg. |
Gary,
i love the GMC Typhoon! what kind of shape is yours in? |
I will draft more trucks next week and see if I can get similar mileage. I just pump up my tires slightly pass max so it'll help. I can't believe I got almost 55mpg in a CA VX! Well, drafting was a major reason ... Gary |
The truck is quick, but it's a brick after 100mph. Mileage isn't that great.. I get about 16mpg or so... but then, that's what my vx is all about... mileage and saving mula.. I take the truck out for fun and to the drag strip, not to save gas. I love the typhoon too!!!! Gary |
I got 56.21 mpg this fillup! This fillup includes a run through the santa cruz mountains (not good for FE). I drafted most of this week and got my first 450+ mile range on a tank (466 to be exact). On my way home from work tonight I drafted a semi. I decided to follow it the long way home since I had a good draft (a semi going contant speed in the same lane), but we ran into a traffic jam. I ended up in traffic for about 20 minutes and I took the side streets home with alot of stop lights. That killed my FE for sure, but I still managed 56.21 mpg!! I guess it helps now that I use the car 90+% on the highway.
In the 3-4 years I've own this car, I've recently been getting excellent mileage! I usually get mid 40's. The car was down for about 10 months due to a bad tranny (Oct 2006-Aug 2007). I changed all the bearings in the tranny (that'll help FE). I also smogged the car so I advanced the timing after smog which drops HC in emission at the expense of increase NOx (a definate plus for FE - my HC is only 9PPM at idle at 15mph which is lower than most VXs I've compared it to). I had a slightly clogged EGR system so I changed out the intake with another stock one that was not clogged. A clogged EGR system decreases mileage (a plus for FE). I can't wait to get lean burn running on this car (CA vx)! Gary |
Gary |
Nice one Gary. :) Looks like you edged me out for your overall gaslog, and you have the CA model. My next fill up should have me in the lead again, tho. :D
