How hard is to install a scangauge II ?
How hard is it to install ? How long does it take ? Any modifications to the vehicle or does it just plug in ? I would be adding it to a 1996 Ford Taurus . Better yet, does anyone have a PDF file they could send me of the installation ?
Thanks, Raz |
You plug it into the diagnostics port... Looking from the driver's side foot well, look up (under the dash area) and you'll see a trapezoidal connector... It plugs in there ;)
Plug the other side of the cable into the scan gauge and you're done ;) |
Oh and the tough part, apply sticky velcro bits, press in place.
Where is the best place to mount it so you can half way monitor it without taking your eyes off the road too much ? Also, how hard is it to transfer from one vehicle to the other ? Do you have to setup different parameters for each vehicle ?
Thanks, Raz |
I'm wondering this stuff as well, just ordered mine an hour ago :)
I mounted my superMID on top of the dash at the bottom left of the windshield, takes the least motion of my eyes to look at it.
Gary |
garyhgaryh -
CarloSW2 |
Thanks carlos! |
And out of curiosity, there isn't a way to get an analogish readout, is there? My aunt's TSX does it,a nd it would probably be easier to pay attention to if there was a bar moving up and down relative to your mpg...but some of your guys' mpg it probably just wouldn't go high enough in that case |
