GasSavers_bobski |
11-01-2007 07:32 PM |
If anyone's interested in why that setup works: The beeper/buzzer/whatever gets power from the lighting circuit. That's pretty obvious... Lights are on, buzzer goes off, ok.
The next part is kinda strange at face value: The buzzer gets grounded to a source of ignition switched power. If you're even somewhat familiar with electrical circuits, you're probably thinking "What? You're supplying power to both terminals of the buzzer? How will that work?" The answer is that it won't... At least while the ignition is on. When you switch the ignition off, you're cutting off the power supply to that fuse. The rest of the electrical gear down stream of that fuse (the defroster in this case) is still hooked up but now unpowered. That means when the ignition is off, you can send power down that wire (via the fuse slot connection) from your own source and the power-starved devices it feeds will use whatever they can get. The buzzer uses so little power (maybe 1/20th of an amp?) that the downstream devices don't appear to turn on, even though they're conducting the power to ground.
