Wal-mart had fiberglass and aluminum screen so I picked the aluminum( took 2 7ft rolls).I expect the motor heat will last longer when parked.I used tie wraps to anchor it to anything I could find ( drilled a few holes for tie wraps also).
What kind of MPG gains are you getting so far with the underbody condom you've made?
I really like this actually, while it won't give the benefit of a non permeable surface, it more than makes up with super easy installation :thumbup: |
Slick. Pun intended.
I really like that the aluminum should hold up well and looks like a really easy install. The whole thing is a lot like the old aircraft cloth that gets painted with "dope". Anyway, let us know how the paint on screen material holds up. If it cracks and leaves holes then maybe latex paint would be the way to go - but you'd have to brush it on; I don't think it comes in spray. |
I just filled the tank again. This time I got 502.1 miles on 12.894gal..I drove 125miles today,up to 70mph at times but mostly around 63 to 67.It was very windy,but warmer today. The screen is keeping the water temp to 130degrees after sitting in 40degree weather for 2 hours.
