1993CivicVX |
11-13-2007 05:11 PM |
Originally Posted by VEI
(Post 81891)
I know your opinion. But I would have several answers, several opinion before make a choice.
Ok, you have not this problem with your new sensor, but sometimes, you have the CEL. Your AFR is perhaps a litle diff?rent, more rich. I don't know.
It's difficult for me to explain my problem.
With the new exhaust manifold (no cat.), the accelerator response is different. The "response delay" is more "brutal".
But before, with d15z1 exhaust, I think I already had a "response delay" and some hesitations in lean burn. (More that when I bought the car).
Maybe I am crazy. It is possible that this is normal. I don't know.
I don't think it is possible it is normal. I think no one has replied to that comment because I think the opinion of everyone else is also that it is not normal. It's wishful thinking my friend in lieu of a $320 fix to your problem. Granted I don't know much about cars, but the little I've picked up about my car on this forum leads me to believe there is little other recourse for you in the matter of your stumble/power lag/power surge issues upon acceleration. I can also say that with my car the problem was worse the lower the RPM, which seems to be true for you as well (at 3900RPM you said the problem was not present) I did have the same problem as you. And through the same advice the people here are giving you, I applied to my own car and the problem was fixed. If you search through the forums you'll find other VX owners who had similar problems fixed by replacing their old o2 sensors. o2 sensors do not always throw a CEL when they are not performing at their best and could use replacing. My car was not giving me a CEL when I replaced the o2 sensor, and yet the o2 sensor was the main culprit to the problem. You may want to try www.honda-tech.com to see if you can elicit a different opinion over there, tho.
The replacement of the o2 sensor had the largest positive effect for my car. The right spark plugs also had a big effect for improving the stumble problem. And I think the other things mentioned can't hurt and may help with that specific problem. Anyway, if I come across a little brusque, I don't mean to be rude (look at my title, I sometimes have a hard time being polite) I am trying to help you. Or at least save you some time.
One more thing: it seems that the life span of the o2 sensors is around 170,000 miles, give or take a few 10k. Your car has around 165,000? Basically, there is no indication that your o2 sensor might be fine, and lots of indication that it needs replacing. Namely the CEL, the bad stumble/power lag/surge and the fact that nothing else you have tried has fixed the problem. Anyway, I suppose you can't be too certain about something when it's as expensive as the o2 sensor to fix.
