New '92 Civic DX (soon to be VX)
Hello all! I joined a few weeks ago...I just bought a '92 civic HB DX (couldn't find any non-riced VXs in the area) w/ 155K miles for $2,500 - still runs great!
*I commute 70 miles RT daily...so this should pay for itself in 3 yrs w/ the gas $$ I'll be saving. first full tank of gas: 381 miles on 9.855 gallons --> 38.7 MPG (90% freeway, going around 70 MPH) plans: -VX engine swap w/ modified head?? (engine is on the way) -VX rims (on the way) -aero stuff (front air dam, under body paneling, wheel skirts,...) -I'm planning 50 MPG and hoping/aiming for 60! pic: https://www.fuelly.com/attachments/fo...d5717e816a.jpg I've picked up a lot of great info here...hope I can continue to learn and possibly give back some too. *I'm mainly into racing/autoXing cars, so this car project is a little different, but still loads of fun for me. |
May I ask, what are you planning for head modifications on the d15z1?
And congrats on picking up the DX, you'll like it. |
https://www.civicforums.com/forums/18...on-ratios.html I'll do all the other easy stuff too: smooth out casting lines, port match,...I had thought of increasing compression by going w/ longer rods (you can usually get a higher compression ratio w/out detonation this way), but opted not to b/c I'm trying to keep costs low. -Peter |
nice i might have to copy you when i do my swap! lol where did you get your motor from? |
JDMSOURCE www.jdmsource.ca 1 866 717 4252 |
I don't know how a VX would react to higher compression. With it already burning lean, and higher compression that it has, I'd imagine the motor wouldn't last very long. Though I really don't know.
I'll have to check out your other thread you linked to. Welcome to the board! |
Good luck on the swap and congrats on your new whip!!
Make Sure you have the right tranny
Welcome another new VXer to the boards. I believe for the EG Civic, the CX/VX had the same gear ratios with a very tall final drive ratio, the LX/DX had shorter gearing and the EX/SI had the shortest, sportiest gearing. I think in order to truly have a VX, you need the motor, ECU, 5-wire Oxygen sensor and correct tranny. All these parts should be available, tho.... good luck!
Doug |
-Engine is being shipped and has the header/O2 sensor/EGR -wheels are on their way (i plan to run taller/thinner tire if I can find one...so the final ratio will be even taller!) -ECU will be picked up this Sat (I'll need to add a few extra wires for the Vtec/O2) ...now I just need to find a 5 sp VX tranny. I"ll probably have a load of questions once I start getting all the parts and begin the swap:rolleyes: |
