1. You are a plane 2. You are wearing roller blades (landing gear) 3. Your engine is a rope that is tied to a pole in front of you (pretend like it's thrust applied through the air) 4. You are standing on a conveyor belt (treadmill) 5. Start pulling yourself forward with the rope and turn the treadmill on You will move forward ;) Why? Because you're applying power through the "air" - not through the ground ;) You will not remain stationary nor will you move backwards - remember, it's airspeed that matters, not ground speed. When I explain in these terms, almost everyone I've spoken with has that "Eureka" moment :p |
If the pump cuts off early on a given tank, you would get slightly higher calculated MPG than you actually achieved. But, that would leave you with a less than full tank. When you run the tank down and fill it back up to full (without the early cutoff), you would fill up that space in the tank that the early cutoff made you miss, in addition to the fuel that was burned. Since the fuel dispensed is greater than the actual fuel burned, the calculated MPG would be lower than what was achieved. |
Some people are just determined to live with their head in their own little ostrich hole. That said.. I see that same "point of view" here sometimes. |
ok.... soo.... any myths or anything you guys think we should ask to be played with!?
I like to get mpg averages over 10,000 miles or so ;) My lifetime in this car is 55.39 over 68,000 miles. Sure a tank might be a bit off one way or the other, but it's got to be pretty darn close at 68k :)
1) Found on Internet 2) Crazy claims 3) Goofy Testimonials 4) Inventor says he's been told it violates fundamental physics, but disregards this 5) He even sells a kit! For a steal of $450+ or custom built for over $800 :rolleyes: 6) Website hosted on tripod :rolleyes: https://quantumgravitics.tripod.com/id3.html |
yea you've gotta love that one!
looks like he's heading for a star trek convention. |
Rick |
