Oh yeah you are already running Mobile 1 well get the tranny oil from Synlube. Stop giving your money away to the oil companies!
It is a 3 to 5 micron colloidal particle size mixture of graphite, TPFE Teflon, and Molybdenum Disulfide (moly) in a liquid carrier which becomes a solid lubricant system. It coats the friction surfaces with these solid lubricants making them smoother and more slippery and provides lubrication without relying upon oil film and oil pressure alone. The engine oil is also a 5-50 weight and will continue to lubricate properly when heated to over 500 degrees. It is just really slippery stuff! |
Dang that sounds cool!
ack
there are better ways to get better mileage out of your car, you would be better off choping the roof, and ripping out the inside of the car, find out what vehicles had simaler trannys, and see if any of them have gearing that is more appealing, but in my mind disabling cylenders should be left to engeners, as even they strugle with making it work.
It bothers me to no end that most carmakers just won't put the FE goodies in 4 bangers. |
gains from el-cheapo, turn off a couple fuel injectors, cylinder deactivation schemes are negligible.
Gains from killing the injectors, closing the intake valve and leaving the exhaust valve open (or closed perhaps) are a little better. Still significant losses in moving the pistons and the air for no reason. Really, you need to decouple those cylinders that are not being used from the drivetrain for best efficiency (and still have a balanced setup). Or just do without the extra cylinders to begin with :) |
a scooter is a one cylinder, a geo got 3 cylinders and a yaris got 4
the thing about disabeling a cylinder is more for a 8 cylinders who OBSVIOUSLY doesnt need at all its for cylinder to keep moving when reaching a certain speed, but your yaris could probably not stand 60mph on 2 cylinders.... hahaha the guys got the best conventional FE machine out there for the years, and he wants better FE, MAYBE the industrie doesnt do enough and spand to much $ on useless piece of performance or luxuary I will NEVER ever fu**** need, but yessssss the making billions of dollars. |
I've been reading this discussion (I'm currently at page 5 of 23) and am not impressed with synlube thus far from it. There are a lot of valid issues being raised there, including why synlube is claiming to meet or exceed certain oil standards while never having submitted their oil for testing. |
