Nope you get the oxygen from the air that combines with the gasoline. All the O2 that was generated with the Hydrogen just recombines with it so it contributes a net zero to added oxygen but it does add combustion heat and a better flame to ignite the gasoline.
The generator gets hot because of the high resistance of the water - by lowering it you reduce the heat I.E. a lead acid battery can produce a lot of gas without really getting too hot with only a few amps once you get the battery voltage over 14.25 volts. The problem with a lead battery is the wasted 2+ volts per cell because of the lead acid chemistry. By using platinum electrodes and sulfuric acid you reduce the plate voltage to a minimum - the voltage that results is what is required to separate the H from the O. Yes I have built hydrogen generators but I used salt water which was not the way to go - never thought of using a lye to increase conduction either. I also have a fuel cell PEM that makes a good amount of Hydrogen and Oxygen separated by the membrane using distilled water at about 3.2 volts and up to 3 amps quite quickly with little heat. It also recombines the H and O and puts out about 2 volts and consumes the gases at a rate proportionate to the current load on the cell. |
flapdoodle -
Have you determined a way to measure the "health" of the electrolyte. In old-school non-sealed batteries, you can use a hydrometer like this : How is the hydrometer used in measuring the charge of a car battery? https://answers.yahoo.com/question/in...0034749AAt2iE8 Quote:
What do you think? CarloSW2 |
I use litmus paper to check the pH of the solution. When the cell degrades, the amperage drops and the solution gets muddy looking. I have a panel mount LED ammeter on the way that will be mounted on the HHO "control panel".
I fear a hygrometer will not tell me much because there is no way of telling exactly what salt mixture is in the solution. For example, when you use baking soda, it starts to change to NaOH immediately upon applying power. You can watch the pH go from 7 to 10 in a short time. |
flapdoodle -
CarloSW2 |
Started reading this forum and decided to join. I have little mechanicle knowledge but have looked into learning about HHO. The best source for building and installing an injection unit that I have found without spending any money can be found at https://smacksboosters.110mb.com/Smack.pdf and https://smacksboosters.110mb.com/Guide.pdf
If you have not seen these, it is worth a quick look. I hope to build one in spite of everyone I mention it to telling me it won't work. Only one way to find out in my mind. |
I like the plate system. Easy, cheap, and probably very effective.
Ok this is my first post. Been reading along and would like to throw some thoughts into the bag. I am NEWBE to all this and would love to get a good design system like Water4gas. You mentioned about the o2 sensors and I have been reading that this is a big hurtle. I have a 95 Cavalier LS which I will be experimenting on. I found this guys site regarding EFEI sensors that he makes. www.pwmpower.com may help solve that problem also there is after Market chips on EBay that trick the o2 sensor into leaning the fuel mixture. Will this work? One more thing since we are ultimately trying to get better MPG would it not be a good idea to take off the catalytic converter in the exhaust since the hho is burning so clean? I mean I would piss in my gas tank if I thought it would help!!! BTW GREAT SITE. We need to get all those HHO YOUTUBE guys in hear as well. MAYBE make a contest or something. You could call it "put up or shut up"!!! OK im done!
Spence -
Part 1: The Intro to Smack https://www.youtube.com/watch?v=CxPQd...x=0&playnext=1 CarloSW2 |
2 efie or not
try this link https://www.thermo1.com/hyboost.htm although you can also find a wealth of experimentation at energetic forums. |
