(*You need the big pumps to push it down the big pipes, but should consumption not demand the capacity of big pipes, you can use smaller pipes and smaller pumps, but have to work them hard because frictional losses are higher....) |
Yup, where we live, water is not really an issue. We just get so damned much of it falling from the sky and running down the rivers that it's hardly on the radar. The largest benefit for us would be in the energy savings of reduced drying times from the faster spin cycles most of the front loaders have. I just wish we could find a standalone spin dryer that worked as well, but everything short of industrial grade stuff looks like it's basically crap from what I can see.
Best one I've ever purchased, Fisher-Paykel. Very programmable, saves power and water, and cleans better than my last maytag.
https://www.fisherpaykel.com/ Sold at Lowes. |
well, we decide on THE most efficient washer at Sears for less than $1k. it's a kenmore(whirlpool) front loader on sale for $699 down from $799.
AND...picked up a $269 pedestal on clearance for $50!!! colors do not match, so what! it hurts, but got the 12 months w/ no interest. |
IMHO, front loaders are junk. This one lasted 4 years and broke twice. It would have been worse but I got it for only $300 new. I had issues with the pump and door. Finally it burned the main board and few other parts. It was used lightly by only 2 people. I asked my mother the queen of clean and she said wash quality was ho hum. Now my washer is not like every other washer, I'm sure there are ones that last longer and are built better. Here's the main problem with the new "breed of washers". Cheaply designed and constructed, planned obsolescence built in(designed not to last), electronic controls. You want whats good, go find the cheapest washer with a manual control knob. It has the least parts and the more dependable technology. Of course my POV is going to be to save money, with a resonable expectation of cleanlines. My latest tactic is to spend $25 or less on a washer. Why? Because even the new ones break! I've got a spare in the garage that cost me $13.
He's a pic of my front loader, it was very satisfying and I found $3 in change in the process. https://www.fuelly.com/attachments/fo...b1e3c6dc91.jpg https://www.fuelly.com/attachments/fo...89dd1313ae.jpg And its $25 replacement. 1970 GE washer. Cast iron direct drive transmission, I felt like an old man after moving this thing be myself, it easily weighed double what it replaced. My how the mighty do fall. Imagine your grandad taking your spot on the rowing team. I did have to make on repair but it was incredibly easy to work because it had something odd called a FRAME. A hose had to be reconnected. I sold this washer after 1.5 years for $25 and replaced it with a newer high capacity washer thats mechanical. Its a twin to the one in storage. https://www.fuelly.com/attachments/fo...cf9787fd08.jpg If you want what I consider the most durable simplest washer you should consider a staber. Its all mechanical. |
NOTE: If you don't mind a 3rd appliance (used between the washer and the dryer), there are stand alone "spin driers" which do a VERY GOOD job of spinning the cloths dry (thereby taking the task of spinning well away from the washer, allowing you to use a much cheaper washer and still get good results). You still need a normal (heat) drier after a spin drier, but you will save a huge amount of energy doing good spin drying first. And as an added bonus, good "spin drying" works as a natural (no chemical needed) "fabric softener", as the spinning process removes dissolved minerals (and other chemicals in your wash water) that can make cloth "stiff" (normal heat drying does NOT remove those minerals, but rather "bakes them on" when the heat evaporates the water off the cloths). FWIW: SPIN dryers aren't very common/popular in the USA (but are somewhat common in parts of Europe). However, there are a few places you can buy them in the USA. For example, I have the following spin drier at my home (~ $150 new, including shipping), and I very much like it. It's manual start/stop (no automated controls), and only spins about 1/2 a wash load at a time. But overall, it seems to do a good job of removing water (and the dissolved minerals in that water) quickly and using only a trivial amount of electricity. This greatly speeds up the later drying cycle (which also saves a lot of energy your normal heat drier would otherwise use). And, as already mentioned, my cloths are now a lot "softer", now that I've been spin drying them after washing (and before doing the final drying in our traditional heat based cloths drier). https://www.laundry-alternative.com/p...pin_Dryer.html |
DracoFelis,
very interesting. i wonder if the spin cycle causes most of the wear and tear on washers? your spin dryer would prove to be most valuable if that is the case. |
The spin cycle of the Fisher-PayKel can be set as high as 1000rpm! The clothes are very nearly dry after that. Also this machine does not have a transmission and uses a direct drive dc motor for agitation and spinning. I'm impressed so far...
What ever you do...don't git the Maytag Neptune front loader washer...unless yer the tinkering type and have money to fix all the problems they had with those.
I got 2 fer next to nothing that I'm tearing apart to learn from. Tech works great...when it's running. One already had most of the parts replaced with the better ones. So I've got lots of modding to do to the other. It only uses 4 gallons of water per cycle. So with the wash and 3 rinse cycles yer only using 12 gallons of water. That's what most top load washers use just fer the wash cycle. ;) |
Ok, so that doesn't account for water heating, so let's throw that in too:
Ok, taking the savings of 11.25 cents on drying and the savings of 17 cents on water heating for a total of 28.25 cents per load, it would take 1415 loads of laundry to make up the additional expense of $400 on a washer. That's allot of loads for the average household - and there is no guarantee that the washer will even last that long. Plus it will most certainly be well out of warranty by that time. My calculations are also heavily skewed toward highest water use for the conventional machine and lowest use for a smaller capacity front loader. Plus the assumption is that drying time is cut in half, but I'm betting most people really only save about 1/3 - and most loads don't take the suggested hour that I used as a basis. So the cost savings are unlikely to even match what I have figured here. (But please feel free to check my math!) That said, I think the standalone spin dryers are a far better option for the money if they work well. But, the last time I went looking for one, the only ones available were cheap countertop crap, and the others were unobtainium. That web site had them listed as out of stock for months. Perhaps I will have to try one out now. |
