-   -   L2H2 for 1998 civic HX (https://www.fuelly.com/forums/f8/l2h2-for-1998-civic-hx-7992.html)
1998HX 04-08-2008 09:44 PM
hellow all. im new to the site and am amazed at all the good info here on this site. i have a question regarding the d16y5 primary o2 sensor in my 1998 civic hx
after 214,000 miles the stock sensor finally gave out. and i looked for replacements and found that the l2h2 was the stock replacement ntk sensor. so i scoured the internet and found a l2h2 ntk 24302 sensor and bought it .
now when i recived it it had a smaller wire harness and different wire colors. figured it was just b/c its not oem honda. well i remove my stock sensor and see it has l1h1 ingraved in it. well do some more searching and i see that the l2h2 is a new updated version of the old l1h1 sensor.
well after 30miles or so i get a check engine code 61 * primary o2 sensor*
is the l2h2 not the sensor that i can use ?? im very stumped b/c every were i look even the vendor states the l2h2 is stock on the hx. and the sensor bolts right in and plugs right in to.
any insight to my problem i would greatly appreciate it alot.
JESSE69 04-09-2008 05:08 AM
Man, I have a 99 HX too. Maybe consult a Honda Dealer?
1998HX 04-09-2008 09:35 PM
anyone . ? i cleared the ecu but still get a cel .
JESSE69 04-10-2008 10:31 AM
There aren't many HX drivers here!
If my O2 goes bad, I have this device to check it and reset my car -
https://www.auterraweb.com/dyforwi.html
https://www.auterraweb.com/windowsscantool.html
