My question was, by disabling 2 cylinders, how will that improve your FE? As far as I can see, you aren't really reducing weight, pumping losses, friction losses, thermal losses, etc. Maybe there is something I'm missing? Would still be fun to try! Nothing wrong with a glorious explosion. If you have some serious spare time, you could attempt to cut out those 2 cylinders, and then weld the crank, block, cam, head, manifolds back together. =) |
I didn't realize that the connecting rod is required to maintain oil pressure, but wouldn't it need to remain pointing up? If you cut it short, isn't it going to spin around freely? I haven't been inside a crankcase since I did a 5hp Kawasaki in high school so it's hard to remember some of this stuff... |
Remove the rockers to the pistons you want to disable and pull the plug., disconnect the injectors of course.
No valve activity will eliminate and intake or exhaust. The only pumping losses you would still have would not be related to air moving in or out of the engine. There would be a slight restriction to airflow through the plug holes, so you could open the holes up some. if you added a tube between the two dead cylinder plug holes it would keep the noise down. I had a 59 Austin Healey Sprite (bugeye) that had two burnt valves (think they were exhaust). Compression was less than 35 psi per cylinder with about 1/5th of the valve head gone. It ran but it didn't have enough power to climb any kind of significant grade. My brother managed to blow the tranny before I figured out whether the mileage was better that the normal 32 mpg. This was in 1968 but I do remember I could get it up to a decent speed. 1 liter engine in about 1200 pounds of car, normally it would do about 82 MPH max. regards gary |
Here you go.
https://www.gassavers.org/showthread.php?t=6137 I should have held the cam followers up with hose clamps so they did not contact the cam. Maybe next time. ;) The V8 on 4 cylinders was a lot more practical. As for leaving rods off of an engine you can do that and cover the hole in the crank with a hose clamp. In this case you would want to make an odd fire engine for best balance. That is leave off 1 & 2 or 3 & 4. I am not recommending this just saying that is the way I would do it. By all means have some fun if you want to. No pain no glory. :) |
he if its anything like my s-10 when 2 of the cylinders were misfiring a few times last winter, you will NOT want to try to pull out on a busy road... i suggest taking it around your neighborhood and gunning it to see how much power you have left, i could barely get going and had to pull over and rev it to evaporate moisture that condensate on the ign module...
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
