Postscript: I replaced the LAF sensor last week. I followed all my fellow posters recommendations. The old VX now runs much better than before-no Check Engine light, much smoother idle, and I'm able to get the rpm's up when slipping the clutch to get going from a standing start up hills again! There's no substitute for having the correct tools to do a job; it only took about 20 minutes to take care of this one.
Considering how much it cost for the OEM LAF sensor (even the item mentioned by djenyc, which is less than what I paid), this is not something a DIY mechanic should try to take shortcuts on. The LAF sensor on the VX is a major part of the technology that enables this model to get such outstanding gas mileage. Make sure to use proper tools and installation protocols, and the job will go smoothly. |
If your sensor is the same size as mine you can take a boxed end wrench run plug and the wires through the opening right down onto the sensor. No special tool needed.
Also, it's a good idea to torque the new one to spec, and that's basically impossible without the right tool. The right tool (either a socket with a slot, or a crow's-foot socket) will also help deal with clearance issues. On a VX with A/C, space in this area is a little tight. I've heard Autozone will loan you the tool for free. |
