Ford model T FE
Not a trick question and I don't know the answer but was wondering if any know what the fuel economy of a Ford Model T was about 100 years ago or a Model A was about 80 years ago and aside from some improved emissions how much we have progressed from that. :)
well what ive heard is the model T nowadays average gets around low 20's
model A's nowadays get averages of around 22-25. the model T never had front brakes, it was rear brakes only and a 2 speed transmission. btw a fun fact is the model A engine made about 35hp. and has a 4:1 compression ratio. so really weve gotten slightly better mpg but 10X more power, less weight, higher revs, etc |
The Model T got about 25 MPG, and the Model A got around 30 MPG, but on TODAY's gasoline they get closer to about 25. Gasoline then was a significantly different compositionl.
I recall that in 2004 when Ford had its 100th anniversary, the average fleet got LESS MPG than in 1904. The Model T was originally designed to run on straight alcohol. Literally it would run on moonshine! |
and if you think about it during the depression theres storys where they would literally use moonshine to get the ol car runnin. im restoring my great grandpas 1929 ford model AA truck so ive found a few forums about the model A. someone did a survey and the average mpg was about what i said mid 20's. some were as low as mid teens some were in the upper 20's low 30's. in those cars its all in how you drive and how well you can set the spark advance precisely to make the engien run most efficient. |
Nice to see real-world results! BTW I was writing my post as you were writing yours - there were no replies when I started my post. Wasn't trying to correct your information, was just writing what I knew.
You should tell people about your restoration project on here! It would be really fun. My neighbor across the road is working on a 1952 truck right now - stripped down to the bare frame, fixing it up to like new condition. He's always in that garage fixing something. I enjoy walking over and saying hi to watch what he's doing from time to time. I bet that our members would like to know how your project goes too! :) |
I had a 37 Ford 5 window coupe, original 95 horse flathead, original 6 volt, original cable brakes. Had it up to 82 MPH once (speed limit in VA was 35 in 37).
It got about 20 MPG. They actaully reduced the carb venturi size when they went from the Stromberg 48 to the 97 in 37. 7.5 to 1 compression was highest of any factory flathead. Tetraethyl lead was one of America's secret weapons in WW2, allowing the US to extract more power from the same size engines as our enemies. After the war the leaded fuels allowed much higher compression that the Model T or A. The flathead engine design doesn't make it easy to reduce the combustion chamber area without affecting the air flow around the valves. The 37 was an easy car to drive in traffic, as long as you watched out for the moron who pulled over in front of you and slammed on the brakes. I used a digital thermometer to balance the brake adjustments by reading the temp of each drum. I could stop the car with thumb pressure on the pedal. Not exactly the topic but I thought it might be interesting. Idle speed was 350 anad the car would pull from 7 mph easily in top gear. Redline was 3800. regards gary |
The model T's didnt weigh much at all, did they? I mean, they were pretty much wood and very very...compact(not the word im looking for)
yes they had alot of wood, but wood was WAY cheaper than metal back then hence why he could sell em for $500, lots of cars for that period had wood in them. yes the cab/bodys weren't huge at all but gotta remember people didn't know what center armrests were, and virtually noone was obese. you are sitting leg to leg to your passengers... haha yea 101 i noticed that last night, i posted then said someone replied already:p ill do a write up on it with a buncha pictures and a video of the engine running |
The 37 was 2500 pounds, with a 223 CI V8.
regards gary |
i do know the model A engine and tranny together weigh about 500 lbs, all iron and steel!!!
