Hi, I have an 03 Pontiac Vibe GT. It's a 6 speed, but otherwise it's nearly identical to your car (same drivetrain, etc) and I've been asking myself the same questions. Here's a few tidbits specific to your car that I've discovered:
- This is the same drivetrain as a Corolla, but the Vibe is a heavier vehicle than the Corolla is. You can't really expect the same FE due to the weight difference. (unfortunate side note, this weight difference also causes the clutches in our cars to quit prematurely although I'm at 57k miles now and still going strong). - The MPGs that you are getting are easily above EPA ratings, so you're not doing bad at all. Are you the sole driver? I've been doing some basic hypermiling for the last several weeks, but my efforts are diminished a bit because it's a shared care and my wife mocks my old-man style driving :). She drives a bit harder than I do and she will not kill the engine at stop lights. - I have not yet modified anything, although the grill block has been calling my name because our grill opening is huge. I might try this in the upcoming weeks. The WAI intrigues me as well, I'll be looking into that. - Other than extreme body mods (wheel skirts, etc), you can at least remove the cross bars on the luggage rack to cut down on your drag. - Same tires as well, mine are just over 40 psi right now and I'm considering going up to 50. - not sure if the lighter weight oil will help significantly (it may, I've just not tried it), but make sure your basic maintenence is up to snuff. Replace your air filter if you haven't in awhile. Let us know your progress, I for one would be interested in hearing what you're efforts yield. |
Hook up behind a big rig with about 3 stripes between you. Thats about 125 feet, close to your stopping distance. In your Matrix that will make the greatest difference. Try 55 MPH or just find a truck that is going that speed.
Slower is better. Drafting and 55 MPh should get you to 40. regards gary |
On my old '03 XR I usually did 36mpg running about 68mph with 50psi in the tires. I also had an automatic though. My best tank was 42mpg doing some serious drafting (read: DANGEROUSLY CLOSE-AKA-STUPID:thumbdown::o ) Do you have the steel wheels/hubcaps 16inchers? Alloy 17's? Alloy 16's? Everything said so far on the thread "should" net you at least 38mpg minimum but I'm a huge believer in big wheels killing mpg's. Ask me how I know..:confused: |
Not sure how close they are engine-wise, but I got an '06 Corolla with an AT and easily average over 40 mpg in the summer. My commute is 80 miles round trip with 90% at 65 mph.
Only mods are a Coroplast grill block behind the regular grill, and tires at 42 psi. I drive speed limit and use the cruise as much as I can. Some drafting, but stay 150 ft back. Good Luck! |
I used to have an '03 Vibe (base model, 1.8 1ZZ engine and automatic, same as the Corolla) and was lucky to get over 30 MPG most of the time. There were some things seriously wrong with that car under the hood that I never got figured out. :( That was back before I really knew anything about this hypermiling stuff also, so I really wasn't trying to drive for mileage - but I wasn't being rough on the car either.
My wife also has an '03 Vibe with the 1ZZ/auto but has had much better luck, usually getting more than the old EPA ratings. She's managed to get around 40 on the highway, not even doing anything crazy - just driving it slow and easy on the throttle. She's driving very little now - 6 mi/day city commute 3 days a week, so I don't know how well it's doing these days other than she has to fill up once every 3-4 weeks. :cool: |
