cruise control
on my recent trip to albuquerque nm i was kind of confused by my cc. i thought that it was supposed to hold the speed in a smooth flow? on my way back i had the cc set to 80 mph the whole way back and noticed that it pulse and glided. :thumbup: i didn't fill up again because i got home around twelve last night and was too tired to do anything. i will try to fill up again tonight to see what my outcome was.
oops i rambled. my question is: did the manufacturers add p&g to cc?? :D |
We're about 2,000ft higher elevation than you are normally in El Paso, could it be that your cruise control was having trouble keeping speed? I run into that in Flagstaff, AZ and they are only about 1000-1500ft higher than the 5,500ft ABQ is at. You should see how my car runs at 10,000ft after driving to the top of Sandia... it's kinda sad.
Now that I think about it, I-25 doesn't have a whole lot of grades and such to cause a problem so who knows! |
I had an intermittent issue like that with my 87 Integra cruise control- up and down by 1-2 mph. It annoyed me so I would turn it off and then reset it. Sometimes just reseting it would get it back to to keeping me at a steady speed.
i would set the cc at 80 and it would accelerate to get acclimated i guess. then it would let up for about two seconds and get back on it for four then get off for two seconds and on again for four, and this was on the flat part of the road. |
chevettes kinda does this, but really really bad, like id set it it would be slowly accelerating all by itself then it would fully let off the gas (manual tranny slows way fast) then gun it to get back to speed...
I'm just curious- I looked at an auto 93 civic ex for sale 2 weeks ago (not running) and wondered how tall the trans was geared. |
My Cressida did this because of a vacuum leak in the CC system.
it only does it if its cold, i bet grease in the cable prolly makes it hang up...
