imzjustplayin |
06-22-2008 12:14 PM |
Originally Posted by suspendedhatch
(Post 107622)
Nonsense. Do you have any specs to back this up? The HX was made into a coupe for the same reason that they added power steering and all the other luxuries. Not for mileage, but to sell the car.
Calling a VX an SUV... those are fighting words.
The 1.5 and 1.6 blocks are exactly the same block. The D16Y8, D16Y5, and my D15Z7 have the same block. Same part number. Same "size".
How can they physically be the same block yet be called two different things? The only way you could have a 1.6L is to have enough volume to BE 1.6 Litres. I wouldn't be surprised if they bored out a 1.5L block to make it into a 1.6L just like when they made the 1.7L block for the 2001+ models. Why else would they be called D series engines unless they made huge overhauls for each incremental increase in litres for the block?
The civic coupe is going to be far more aerodynamic in the rear than the civic hatchback. The civic hatchbacks drop off far too steep, like an SUV which is why I made that comparison. https://www.gearlog.com/2008/02/modde..._honda_civ.php
What that guy did made the CRX far more aerodynamic because of what he did to the rear, not so much to the front. I was very surprised to read that most of the drag a vehicle has occurs towards the rear of the vehicle but if you learn about fluid dynamics, it'd probably make sense. I believe it's mostly attributed to creating a negative pressure behind the vehicle, so when you have sort of a diffuser, that is when you can significantly improve aerodynamics.
Maybe the VX hatchback has additional aerodynamic features that aren't visble in order to make it more aerodynamic than the coupes. Though if everything is the same aside from chassis shape, the Civic Coupe should be more aerodynamic.
