SO Jay2 does the scangauge say "LOL" when you press the pedal to the floor?
sorry, I couldn't help it :) |
-Jay |
I think I figured out where my WAI is coming from... GMC was ingenious... the truck has solar WAI! Let me explain. This morning even after the truck was warm my intake air temps were still right at ambient air. When I noticed the high intake temp yesterday I had only driven about a mile, and the truck was parked in a nice, sunny parking lot for about 30 or 40 minutes. The intake air is ducted through the passenger side fender. Right now I'm pretty sure if I had taken the truck on the highway after a few minutes the IAT would have come down to ambient, or really close to it.
-Jay |
That's right, I forgot, my truck's intake comes in from the fender too. I wonder if dark GM full size trucks get slightly better mileage than light-colored ones...
-Jay |
sorry, busy weekend. yea I forgot, I had to go with beefyride3. that is me.
like I said before, I haven't been on there in some time. the last time I was on there I was looking at a set of camshafts for my truck that would yield about 50hp and 60ft/lbs....and then gas went to 3+ a gallon. my focus was shifted at that point...and I bought a house. the cams would have put me in the high 13s but she is still a little rocket. I still enjoy the old truck from time to time. and back on subject, have fun with the scangauge. try out all the functions so that you can decide what is right for you. also a little trick I thought up (haven't tried it though) with another scangauge and a piece of cat-5 cable, you should be able to daisy chain two of them together to display 8 parameters instead of just 4. I can't justify the cost but it should work if one wanted to do it. |
I would say that the engine load is a pretty good one but the open/closed loop one could be changed. over time (if you haven't already) you will stop using full throttle or even more than half. that is the only time other than warm up when most cars are in open loop.
yo can also monitor throttle position which may help more than engine load. maybe in conjunction with engine load. it is a fun little gadget. I am still playing around with the idea of daisy chaining two of them together but I am pretty cheap so it probably won't happen. I would buy one if they sold one that would display 6 items at a time just because I could resell the one I have to make up some of the difference. we can always hope. |
Maybe I'm just old school. -Jay |
you could get part of that info from the engine load. it will be a guestimation though. you can also get the air/fuel ratio but I think they are all about 14.7:1 unless you are in open loop. also you can program in horsepower which is a real eye opener. I usually run 30 or less. amazing what your actual HP is vs what your peak is.
now that the hot summer days have come and gone (may come again) and my engine didn't overheat, I am taking off the water temp on mine and I have an extra space on mine. I have instantaneous MPG and trip MPG (the one that resets after every cycle of the cars ignition) and IAT sensor reading. I used to have water temp but now I have a decision to make. I do have time though. I also have an extra cable that I ordered. they actually sent me two by mistake and told me to keep the other one. I was thinking of selling it. I originally wanted an extra cable to have so I didn't have to undo my setup every time someone wanted me to check their check engine light. |
