GasSavers_GasUser |
07-20-2008 03:11 PM |
Originally Posted by Ven
(Post 111592)
I understand pulling extra power puts an extra load on my alternator. I am pulling 20amps total (about 240 watts in all) and I'm trying to figure out how much FE this is costing me. I am running HHO and am looking for an alternative power solution. First, I am trying to determine if it will be worth it.
If I had the engineering skill and money to waste i would build a solar panel and install it in place of the car body to run the whole car. Of course you couldn't justify the cost to build it just for the difference in the gas savings over a regular gas burning car, but from a technoligical standpoint it would be worth it.
I don't think you should be so overly concerned about the 20 amp draw as it relates to gas mileage. If you need the 20 amp draw use it and forget it. If you don't need it, then don't use it since at that point it would certainly be a waste. Just wasting gas for "no reason" would be worse.
If you are really really really concerned about gas mileage then do what my Son did and put a motor on a bike and get 150 mpg. He rides it to work every day and uses 1 gallon of gas per month. Of course, he can't ride it in the pouring rain/snow/etc, or go grocery shopping, pick up a load of lumber at Home Depot, etc etc, but that is what his vehicle is for.
Just use the 20 amps if you want/need it.
Of course, this is just my opinion.
