thornburg |
07-30-2008 05:15 AM |
Originally Posted by BEEF
(Post 113050)
holy cow, CVT kinda sucks for FE because if you take your foot off of the gas then it slows down like you are breaking. at least that is what I have been told. it was an option on the hondas at one time and a guy around here had one and it drove him crazy. thanks for the heads up.
It may drive some people crazy the way CVT works, but, generally speaking, CVT is better for FE than a conventional automatic, and sometimes even better than manual. The reason is that a well built CVT allows you to keep the engine at its most efficient RPM while accelerating/driving at any speed. The key is that the CVT be well designed (I assume Nissan's is, as they generally make quality products, and they have been doing CVTs for a while now), and that you learn how to drive it. Some people probably hammer the gas with a CVT because they are used to shifting and variable RPM--if you want higher RPM in a CVT, you must push the pedal harder--the RPM won't increase due to shifting, because there is no shifting. If you let your foot off the throttle, then you should slow down a similar amount to what you would if you did the same thing in a regular automatic.
If you look at the EPA ratings for the Versa, the CVT is rated higher than the manual:
2008 Nissan Versa:
CVT 27/33
Manual 26/31
Automatic 24/32
All that having been said, it is based upon research I have done into CVT, and reading about cars with CVT, but I have never driven one. If I had $15k-20k to buy a new car right now, I would strongly consider one with a CVT, personally.
