Noob mpg guy
Hi guys and gals I'm mike. 26 years of age and been building dsm beasts for the last 10 years. Well I've turned over a new leaf last oct. Sold the gas guzzelin dsms and bought a del sol with a d15b 3 stage vtec. The car was otherwise stock. It's the si model and still has the short geared trans and also has the stock obd2 p28 ecu. I have not checked to see if it's chipped or not put everything seems to work as advertised (38 mpg). My goal is to get a real good lean burn tune going I've used jackal to tune dsm via ostrich but thinking about going neptune. Well know that I've got that off my chest (phew) I just want to say I'm glad to be here.
Re: Noob mpg guy
Welcome!
Re: Noob mpg guy
You have a great engine to start with. I own a 91 AWD Eagle Talon running lean burn with ECM Link management (was running Jackel speed density)and a 93 Honda Del Sol running CROME PRO management with Moates Ostrich and a P28 ECU. I was running Neptune on the Del Sol with a turbo-charged 1.6L SOHC Z6 ultra lean burn head but have recently installed that engine and Neptune system in my son's Honda. Now my Del Sol has a N/A 1.5L SOHC engine. Still running CROME PRO. When are you going to check to see if you have a socketed P28? |
Re: Noob mpg guy
As soon as I can I have sockets to install and I still have my ostrich 2.0. What would advise? Crome? Or Neptune I know there is free software for Crome but how tunable is it? I just hear alot of bad things about it. Socketing isn't a problem I've done many I just don't want to do things twice if I go to a demon.
Thanks for the welcome guys! |
Re: Noob mpg guy
So if I had a choice I would always pick Neptune. The reason I went with CROME is its free and I currently have way to many management systems. (Haltech,SDS,AEM,ECM Link,Autronic,CAT Systems,Hondata)etc... Anyway Good Luck with your project!!! |
Re: Noob mpg guy
Thank you for the info. Question, do you happen to have a stock base map for the jdm d15b 3 stage vtec for Crome?
Re: Noob mpg guy
Re: Noob mpg guy
Thanks any ways. It's not a EPROM p28. And it's not chipped.
Re: Noob mpg guy
I will check to see in my ecu stock if I have any extra eprom-P28 ecus. |
Re: Noob mpg guy
Please do and let me know how much you want for it.
