custom stats..
I set up custom stats and saved it & the next time I logged on the custom stats are gone!
What's up with that? Do I have to set up custom stats every time I log in?!? |
I just noticed the same problem.
This should be fixed as of this morning. Please double check on your end and report back if you have any other issues.
Thanks! |
It seems to be saving now, but the boxes are not showing years or other info to identify them. They all look the same for any year set up.
I just tried setting my custom stats up again, and there is still something funny going on.
I set up 12 different stats, and when I said "save & finish," they came in all jumbled and out of order. Then when I tried fixing them, they got jumbled again, and only 10 of the 12 came through. |
Are you sure that you didn't duplicate 2 of them? Duplicates won't be displayed.
I used several of the same stats (aka MPG) but with different durations (1 month, 6 months, 1 year, etc). There was no problem with this on the old system.
By duplicate I mean the same period and the same stat. I have not been able to duplicate the issue of less stats coming back unless I duplicate a period and stat.
Meaning, I can't place two Avg Mpg / All Time stat boxes. |
The stats are saved in the order that you submit them and retrieved in the same order. If you would, please record which stats you are submitting and having an issue with. I will try to reproduce with the same list. |
