Thanks for posting the updated version. It appears to be working for at least the entries that we need. Nice work guys!
Will there be a point where we will be able to do our entries cross-platform either android or iOS? Looks like you guys might be heading towards a unified Application across the platforms. |
I only see
1st line : Date $Total 2nd line: Litre $/Litre The second line used to be: Litre L/100 $/L Not a big deal since if I click on the entry I can see the L/100 |
Using 2.7, still crashing intermittently when going to edit a fuel record. If you can get into edit, there is no 'keyboard' to edit odometer readings.
As for the keyboard, go to Settings -> Adv Settings -> Number Pad -> and be sure they are set to active (green). |
Ta. |
Argh! All my data appears to be corrupted after installing the updates.
All cost/L and the L filled are wrong up to June 2014. What did your math engine do? How do I recover the original data :mad: |
To fix this, do the following: Note: if you have not tapped Sync since recovering the data and changing the units, you may skip to step 4. 1. change the units back to MPG (US) 2. go to the Setup/Login screen and tap Delete Synced Data 3. return to the main screen and tap Sync 4. return to the Setup/Login screen and tap Delete Local Data 5. change the units to what you had been using all along 6. return to the main screen and tap Sync. All your data should now be properly restored. I would recommend emailing yourself a copy of your fill-up data prior to deleting the Sync data- https://www.fuelly.com/gascubby/suppo.../gcexport.html |
