Quote:My wallet is
Put me down, m8. I've been
Put me down, m8. I've been pretty consistent as of late with my gas mileage.
LOL, my mpg is all over the
LOL, my mpg is all over the place.
dissolve?
It would be nice if the Company would provide a video of the pill dissolving for us. I replaced my gas tank, sending unit, and fuel pump screen back in 0ctober 2005.
My MPG spread has been low lately too. BUT my area warms up THIS coming weekend and I got some smooth wheelcovers that I will install on Sunday too |
Siphon screens!!!
** Caution ** It's been reported by a rep of the company posting on another forum that unless you're 100% SURE that your tank doesn't have an anti-siphon screen at the bottom of the filler tube, then DON'T drop any pills in there. Apparently, a number of people have reported putting the pills in their tank and after adding pills a couple of times, they get gas shot back at them because the pills have accumulated on the anti-syphon screen and are now blocking the tank inlet. I don't think people are thinking about this potential problem until they can't get any more gas in their tank without a mess. Hope this helps keep anyone from getting drenched.
Re: 40 gallons
RH77 |
For the turbo you can just
For the turbo you can just take out the spring on the wastegate which'll prevent it from running in boost at all.
I've read about comparing
I've read about comparing turbo, and non turbo diesel VW rabbits, and how they both got about the same mileage, partly because they are not relying on spark ignition, that more air ment more compression, and that ment more heat to burn more of the fuel, that deisels are alwas running wide open, that it's only the amount of fuel going on that changes, and that average diesels runing under normal load are running a 50:1 air:fuel and can go as lean as 200:1, comparard to the 15:1 with gasoline.
MPG CAP testing
Hi guys, wondering how you are going with your trials of these caps..
I have some myself and are running my own experiments, id like to compare if we could. Thanks Robyn |
I've got some magic beans for sale if you want some...
