Rechipping the transmission
I called a couple of transmission places today to see if the could reprogram the shift points on 3rd and 4th gear. They acted like I said the moon was made of cheese and why you would want to do that. Long story short they said you couldn't. Has any body looked into this or run across it online? I think it could be done and if you could change the shift point by 5-8 MPH it would make a pretty big improvement on FE.
Re: Rechipping the transmission
I imagine though that once the spot is found where the shiftpoints are located it would be very easy to do. |
Actually you can buy a
Actually you can buy a transmission module that hooks up to the car's transmission module and you can program it anyway you want. It costs $800.
I assume you have a damn TCU
I assume you have a damn TCU (wiki me, please!), so it's prolly a pain in the ***. Sure you have no kickdown cable?
No kickdown cable. I'll just
No kickdown cable. I'll just have to wait for the transmission to creater and see about doing swap to a manual.
