heres what i've found out.
obd1 (color) -> obd0 B7----(grn)------B7 P/N in B4---(grn/blk)---B11 D4 in B3---(grn/blu)---(add) D3 in A19--(yel)-------A8 TC lockup (i hope your right svoboy.) A17--(grn/blk)---DONT USE see up svoboy. D18--(wht/red)---A10/mpfi/ps9 / B12/dpfi (interlock cntl) as soon as helga is better and not beeing so *****iy on her period i will test the above. |
The auto ecu will just give
The auto ecu will just give you a code since you're not using the partial lock-up and it'll be angry.
You should just wire a19 to 12v and be done with it on a manual ecu. You can ground out the park switch inhibitor thing so you can shift around without pushing in the lock. |
