I'm just full of advice
Never forget to torque your lugnuts. :(
OR ELSE? What will happen, Mr. SVOboy?
Or else you'll think you'll have a bad wheel bearing and obsess over that for a day until you remember you didn't tighten the lugs and you go out and your driver side front wheel is almost falling off.
AH! Don't feel bad. I've done that often enough (well not too often) that I recognize the sound of a loose wheel and can distinguish it from a bad wheel bearing :)
Yeah well, now I can go autocrossing, if mother permits.
Probably killed your FE to.:p
Nope, not really. It was better than it was after I fixed it, :p
i think it was the wire tuck, cut down on engine bay aero drag, :)
