Gaslog graphs + Mods
Matt -
Maybe this has already been suggested, but it would be nice to have a "modification entry" as well as a gaslog entry. In this situation, a user would enter a change that they made to the car on date mm/dd/yyyy. In the gaslog, this would show as a vertical line at the appropriate date. In the "gaslog table" this would be an entry that looks something like this : Date_________Distance__Fuel Used__Cost of Fuel_Notes__________________MPG(US)__operations 01/05/2007___NA________NA_________NA___________Added Warm Air Intake__NA_______edit This way, we would be able to note MPG trends after mod "X". We would refer to the table to see what the GasSaver did. Just an idea (as if you have the time!) CarloSW2 |
Mehbe a dot on the line that's clickably linked to a generic post about each mod xor a specific post about the mod by that person...
I really like this idea. I'm actually scared to look the code behind the garage/gaslog. I've been coding a few other plugins recently and I remember how much of a hog-pog coding job I did.
Anyway, I'll brainstorm this a little bit and get on it. |
The other change I'd like to see in the gaslog graph is to have the horizontal axis scaled and labelled by time; that would help those who live in places with seasons. |
Yeah the months at the bottom would work really easy Letter and two digit year...
Matt -
I tried a trick once. I put in 0-0-0 for Miles-Gallons-Cost in order to try to insert a "mod between fillups" gaslog entry. It didn't effect my MPG calculations. The 0-0-0 entry didn't even show up on the chart as a "mini dive" in the data. However, the next day, the 0-0-0 entry was gone from my gaslog :( . This leads me to believe that you have a "null gaslog entry culler bot" in your gaslog code. If you just left the 0-0-0 entries alone, at least they could serve as simple "mod log" entries. CarloSW2 |
Does anyone have as irratic a gas log graph as I have? It really jumps all over the place.
you've got to remember that your Toaster is greatly affected by wind. So I'd say that it jumps around a lot due to wind conditions not being consistent from tank to tank.
Your adds are all over the place, try filling at the same station and using the same fuel adds over a couple of tanks so you can get some idea of whats really happening. I would suggest no more than 1oz. per 10 gal. on the gp7, more than that drops the mpg in my cars. |
These fluctuations were less appearant in the summer months. |
