Power Draw from alarm clocks/Microwaves
How much does a new type alarm clock use?
Also, how about a microwave from the 70s v. a new one? :) |
I've read alarm clocks take ~10W. I have a microwave from the early 80s w/ the digital readout/stuff that uses ~2W, while my grandfather's version, w/ more features, but basically the same thing, uses ~4W. I'm guessing it's just due to difference in chip design/availability.
Remember that suff plugged in pulls a draw. My stereo, TV, DVD setup connected to the power strip all draw about 15W just from being plugged in the wall outlet. This is when they are all not running and turned OFF, not just in standby mode. So now I power the strip off and run 0W from my entertainment system when Im not home. It may not seem like a lot but Im sure it will add up. Looking forward to see what next bill will be like. Anyway, hopefully I remember to check my wattage tonight. https://www.gassavers.org/gaslog/sig.php?id=547 |
I own one, but being in japan at the moment, I don't have access to it.
I'm actually more concerned with in use power draw of the microwave... |
I look at microwaves and clocks from a 'they are what they are' perspective. It's really not practical to unplug them, so ignorance is bliss!
We've figured out however that we can now combine our two independent satellite receivers into one combined unit for two TVs by upgrading to HD format. Assuming it doesn't draw much if any more power than our current receivers, we'll be cutting that parasitic load of 40W, 24/7, in half. Anybody with the HDTV DVR from Dish want to confirm or debunk that assumption? |
I don:t mind the microwave clock, but Im thinking of getting a new one for my mom for her birthday thatll use less power in run mode and such things.
Also, I have been using a windup clock here in japan and wonder if the power draw is worth using it in the us too. |
Another solution to the power strip switch is a GFI outlet. Assuming the first one in your string of outlets is more convenient to reach, you could shut the whole string down with just a tap of the button. That's how we shut off our entertainment center at night, as it's wired on the same circuit as the kitchen GFI.
Rick |
