Seafoam lowered my idle!
At first I was a bit scared of using this stuff, but I figured if so many people have success with it, who not give it a try.
My VX used to always idle at about 900 RPM when it was fully warmed-up instead of around 500 RPM like it should. Aftering using Seafoam, it idles low just like it's supposed to! :D It was a bit scary seeing that huge cloud of white smoke behind the car, and hearing it idle terribly with the brake-booster vaccum line detached was annoying, but it was worth it. After I took it to redline a about a dozen times on my drive to "clean out" the motor, the engine stopped smoking, and now idles better than ever! Great product! I added some to my gas and oil too to hopefully give the engine a full cleaning. |
Congrats, chalk another one up to Seafoam.
umm, shortly after I bought my car I brought it to Jiffy Lube where they did a similar thing. I didn't think it was seafoam they used, but your description is very similar to what they did. They said it was cleaning out the exhaust system, though, and never mentioned seafoam. Was it something else they did? I'll have to dig up the post I made about it.
I really need to get the complete OEM intake installed though... The way I have it in there now, it is still sucking cold air, which can't be good with these COLD temperatures around here lately. HOpefully I'll get it installed tommorrow so it will suck up only engine-bay air. |
^^ Mazda has a seafoam type stuff for their cars... The KL series engine is non interference, unless carbon build up on the valves gets really bad (ya, tolerances are damn tight) - to the point where carbon knock is an issue. The TSB says to use their version of seafoam, but to let it soak overnight (or maybe it was 60 minutes?).
The factory civic intake actually pulls all of its air from the engine bay (minus the resonator box, but I'm taping off that hole for that and am not installed that heavy box), and with a small modification, I could have it pull all of the air from the header area with about a 1ft addition. I'll have to take a picture of what I'm talking about once I get it installed.
^^^ sounds like what I did with my stock VX intake. I left the resonator box behind the bumper and all the other OEM piping in place. All I really did was get some aluminum dryer vent (expandable kind) in 3" diameter. Then I just sccrunched it over the top of the intake tube that sits behind the radiator and directed it over to between the manifold and the block.
