Suggestion: Save/Re-use Notes - Fuelly Forums
Old 03-16-2010, 11:38 AM   #1
I use the Notes section to record the name and address of the station where I filled up. (My thinking is that I can export this to see whose pumps shut off early vs. late.) I would like to have the ability to save Notes, because I typically only use two or three stations.
Alternatively, if I could just save one particular Note for my profile (or per vehicle) that would be better than nothing.
RKBA is offline   Reply With Quote
Old 03-16-2010, 12:45 PM   #2
pb
Notes are completely free-form so people use them for all kinds of things. We're probably not likely to build saved notes into the site, but you might be able to come up with a system to make it easier. Maybe you could visit your profile page before each fuel-up, copy the text, go to the fuel-up page and then paste into the notes field.
Old 03-22-2010, 04:47 AM   #3
Not if this is a bug, but defiantly need to look at it.
I made partial fuel up - and check check box. Got my record - system recognize that this is partial fuel up - no MPG calculation.
Week later I add full tank fuel up - but my MPG is not calculated.
You can check by your self on my profile.
Thank You
MB330 is offline   Reply With Quote
Old 03-22-2010, 11:46 AM   #4
pb
MB330, check out the FAQ on partial fuel-ups: "Once marked, Fuelly won't calculate MPG for that fuel-up or the next." Once Fuelly has a full tank to work from again, you will get an individual MPG calculation for a fuel-up.
Old 03-22-2010, 01:48 PM   #5
Thank You
