Tire sizing odometer modifier? - Fuelly Forums
Old 07-19-2009, 08:18 AM   #1
BDC
Adding a percentage modifier to odo readings automatically?
So say you have a car with bigger diameter tires than the car was sold with stock. For example, I have a 205/50/15 tire on one of my cars which was sold with a 185/60/14 wheel from the factory. The overall tire diameter is about 1.5% more than stock. Thus, the vehicle's odometer, being calibrated for the smaller tire, will tell me that I went 1.5% less distance than I actually did.
I understand this is a real simple thing to do with a calculator, but perhaps there is an option to add or subtract a certain percentage of miles from every reading you log on Fuelly. And perhaps a link to a tire size calculator. For some people this can end up being a significant difference and is rarely considered.
BDC is offline   Reply With Quote
Old 07-19-2009, 08:21 AM   #2
My tires make my speedometer off by 7%. I run a Scan Gauge 2 with that percentage programmed in to give me my correct speed. When calculating my tanks for Fuelly, I just add 7% to what my trip meter shows.
rjhodges12 is offline   Reply With Quote
Old 07-20-2009, 12:24 AM   #3
BDC
Right, I am asking for a way to automatically do that rather than making an extra calculation every time I add a fuel up.
Old 07-21-2009, 09:35 PM   #4
Member
Scan Gauge actually adjusts it. My tiress are stock size but my spedometer and odometer are off a little. You have to get a GPS go down the highway and adjust Scan Gauge MPH to the same as the GPS. Now your Scan Gauge will give you how many miles you actually drove. Over a tank full for me my Odometer says about 4 or 5 miles more than my scangauge. I just use the scangauge number for more accurate numbers. Get one you will like it! LOL!
later
erick
VWJunky is offline   Reply With Quote
Old 07-22-2009, 01:38 AM   #5
BDC
OK, so for those of us without OBDII...
Old 07-22-2009, 01:45 AM   #6
Member
GPS or pad and paper. My old cars I just have to wing it.
Later
Erick
Old 07-23-2009, 05:56 AM   #7
http://miata.net/garage/tirecalc.html
this won't do it automatically, but it's good for quick calculations.
Old 07-23-2009, 02:50 PM   #8
I took the RPM (revs per mile) posted @ Tire Rack for the OE and replacement tires, which amounts to a 3% difference for the taller replacement tires. I multiply the trip meter reading by 1.03 and divide that by gallons used. Sometimes I even do it by long division, it's not that difficult.
2015 KIA Soul+ Solar Yellow, Pirelli P7.
Neanderthal is offline   Reply With Quote
Old 07-25-2009, 01:23 PM   #9
That Miata calculator is not accurate. I've run a few calculations with sizes from TR and it doesn't add up. Kinda blew the easy way.
It would be nice if there was a calculator built into the site here, no way to correct for the 1.03% that my different tires contribute to MPG.
Old 07-25-2009, 08:52 PM   #10
well here's another...http://1010tires.com/TireSizeCalculator.asp or this one...http://www.euroshina.com.ua/calc.php...=13&lng=en
